example Use Case
Control Surfaces
panel
With DataMiner Visual Overviews, based on Microsoft Visio, you can create your own control surfaces and panels. Buttons, levers, rotary knobs, etc., all customizable to your needs. Simply assign actions to any of those control elements, starting from a simple parameter set or router crosspoint, up to the execution of any complex automation script or workflow.
Our surfaces can run standalone but also act as software copy of one of your hardware control panels.
By the way: DataMiner is not limited to Microsoft Visio, with DataMiner Dashboards we also support HTML5-based control surfaces and control panels.
audio console
master control switch
PGM / PVW interface
