integration Use Case
Bridge Technologies – Tech Partner Integrations
Bridge Technologies
Have a look at this use case to check out how DataMiner low-code apps are used to integrate with our Tech Partner BridgeTech.
- VB440 appliance
Interested in trying this out? Then have a look at our catalogue to download our VB440 sample app which you can use free of charge (VB440 connector is required).
Select one of the VB440 appliances on the landing page of our sample app to get a high-level overview of all services that are being monitored and analyzed. DataMiner also monitors the VB440 hardware, including metrics such as CPU temperature, free disk space, and RAM.
Select a service to check all associated elementary streams (ST210-20, -30- 40), its bitrate, source IP and multicast IP, and much more.
This is an example of Bridgetech's new widglets showing video, audio, waveform, and vectorscope.
This widglet is acting as a multiviewer decoding multiple ST2110 streams in parallel.
This last example showcases a widglet with built-in controls, for example to switch inputs or switch between different scope views.
