integration Use Case
Arista – Tech Partner Integrations
Arista
With a variety of DataMiner dashboards, this use case shows how you can visualize and manage data from our tech partner Arista, starting from switch infrastructure monitoring and checking the firmware and hardware status information, up to the most detailed parameters and metrics.
This dashboard is used to monitor an Arista spine-leaf network and its most important metrics and KPIs.
Keep a full overview on your Arista switch fabric. Use the DataMiner node-edge component to show alarms on nodes (interfaces) & edges (switches), and use the built-in analytical features to check the PTP state of each interface. Click either an interface or a switch to populate the trend graphs.
Use this dashboard to keep a 360° overview on your Arista spine-leaf fabric and get real-time access to interface info, SFP data, and also your PTP KPIs.
On this dashboard, you can try out the differences between polling and OpenConfig streaming telemetry data on an Arista switch.
And here is another example of how you can monitor SFP data and all details of your switch interfaces.
