Why are my DVE protocols not updated when applying a new protocol to existing element?
Solved2.01K views2nd December 2022DVE protocol
Brecht Deconinck [SLC] [DevOps Member]1.37K 18th November 2022 0 Comments
When applying a new protocol (protocol with different name), to an existing element and choosing to use the same element, the DVE elements are not updated to the new DVE protocol.
The 2 protocols are in sync regarding the parameter IDs, saved parameters, etc. so there’s no mismatch regarding the stored element data.
I.e.
Main element X (protocol A) has 2 DVEs (protocol A – X)
Applying protocol B to element X works, but the DVEs are still running protocol A – X and not running protocol B – X.
Brecht Deconinck [SLC] [DevOps Member] Selected answer as best 2nd December 2022
Mieke Dryepondt [SLC] [DevOps Advocate]4.26K Posted 21st November 2022 2 Comments
Hi Brecht,
Could you provide a bit more info:
When you indicate the protocol name changed, do you mean the new selected parent and its exported child protocols are different then those used?
If not I believe you have conflict problem of having 2 parent protocol exporting the same child protocols. This could explain the behavior you are seeing.
Brecht Deconinck [SLC] [DevOps Member] commented 21st November 2022
Hi Mieke,
When applying a new ‘main’ protocol (which also supports DVE protocols) to the main element, the main element’s protocol is updated to the new selected main protocol.
However, the DVEs for the particular main element remain (so not deleted and re-created), but those DVEs do not have the new DVE protocol related to the new ‘main’ protocol. They’re still running the DVE protocol related to the previous ‘main’ protocol.
Mieke Dryepondt [SLC] [DevOps Advocate] commented 24th November 2022
Brecht,
Then this sounds more as an issue although it can be debated if this is an advised action to do.
Please make an issue task for this so it can be looked into by our experts.
