Where are Custom element properties stored?
Solved1.04K views24th November 2023
Piotr Borowski [DevOps Member]550 24th November 2023 1 Comment
Where are Custom Element properties stored, in a database (I have MySQL - please provide the table) or in XML files?
Piotr Borowski [DevOps Member] Selected answer as best 24th November 2023
Piotr Borowski [DevOps Member] commented 24th November 2023
OK I see in Element.xml file of the Element 😉
João Severino [SLC] [DevOps Enabler]14.52K Posted 24th November 2023 0 Comments
The actual value of the properties is indeed found on the Element.xml file inside the folder available for each element
You can read more about it here Elements | DataMiner Docs
