What’s the best way to update a custom booking property from an automation script?
Solved1.47K views11th October 2021SRM
Jochen Dewachter [SLC] [DevOps Member]2.17K 8th October 2021 0 Comments
What's the best way to update a custom booking property from an automation script?
Jochen Dewachter [SLC] [DevOps Member] Selected answer as best 11th October 2021
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 8th October 2021 0 Comments
Here is a code sample:
using System;
using System.Collections.Generic;
using Skyline.DataMiner.Library.Reservation;
using Skyline.DataMiner.Library.Solutions.SRM;
public class Script
public static void Run(Engine engine)
// Replace with reservation guid
var reservationId = Guid.NewGuid();
var properties = new Dictionary<string, object> { { "testproperty", "testvalue" } };
var reservationInstance = SrmManagers.ResourceManager.GetReservationInstance(reservationId);
reservationInstance.UpdateServiceReservationProperties(properties);
