What is the least impacting (safest) way to read a lot of DomInstances?
Solved2.44K views20th September 2023Automation CPU DOM Memory
Mieke Dryepondt [SLC] [DevOps Advocate]4.27K 20th July 2023 0 Comments
What is the advised method to use to avoid a massive load / memory usage when logic needs to retrieve DomInstances where the result could vary from 1 to 1 million (depending on the filter) ?
Option 1 (basic):
This will simply read All the DomInstances that matches the filter. So I’m expecting a big impact (timeout?) in case we are reading a lot of data.
public static List<DomInstance> GetAllDomInstanceByFieldValue(this DomHelper domHelper, FieldDescriptor fieldDescriptor, string value)
var filter = DomInstanceExposers.FieldValues.Field(fieldDescriptor.ID.Id.ToString()).Equal(value);
return domHelper.DomInstances.Read(filter);
Option 2 (paging):
This will get a set of DomInstances per go. (spreading the load somewhat)
public static List<DomInstance> GetAllDomInstanceByFieldValueByPages(this DomHelper domHelper, FieldDescriptor fieldDescriptor, string value)
var allDomInstances = new List<DomInstance>();
var pagingHelper = domHelper.DomInstances.PreparePaging(filter);
while (pagingHelper.MoveToNextPage())
var currentPage = pagingHelper.GetCurrentPage();
allDomInstances.AddRange(currentPage);
return allDomInstances;
How many items are retrieved via 1 page?
Option 3 (Skyline.DataMiner.Net.Tools):
I found this, but I don’t know what it does or when this should be used:
public static List<DomInstance> GetDomInstances(this DomHelper domHelper, List<Guid> instanceIds)
var instances = Tools.RetrieveBigOrFilter(
instanceIds,
id => DomInstanceExposers.Id.Equal(id),
filter => domHelper.DomInstances.Read(filter));
return instances;
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 20th September 2023
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 20th July 2023 0 Comments
Hi Mieke,
If retrieving a huge amount of DomInstances would be required, paging is the way to go. Keep in mind that the example you provided will load all these DomInstances into memory. If these could potentially be a million, you could push SLAutomation out of memory. In that case, it is recommended to get a page, do your actions, and then get the next page. That way you are only using the amount of memory that one ‘chunk’ needs.
Do note that this is not a definitive solution as it always depends on the use case, but the general rules to keep in mind are:
– Try to limit the size of the messages sent between server & client
– Try to keep the number of objects loaded into memory in mind
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 20th July 2023 0 Comments
Hi Mieke,
Option 1 is the most common way to do it if you expect not too many instances.
Option 3 is the same as option 1, but instead of using a field value it is based on a list of specific DOM instances. The tools method is a converter from a list of GUID to a big OR filter (database query.
Option 2 is recommended if you want to handle instances in chunks.
By default, this has a size of 500 objects.
So if your result is 1300 instances, then you’ll have 3 pages.
You can then create a sort of subscription system to handle these chunks, like for instance filling up a table or so. However, with your current example, it will not change in behaviour. because you iterate all pages in same thread and send it all back in 1 list.
Hope this will help you further.
Matthias Declerck [SLC] [DevOps Advocate] Edited answer 20th July 2023
