Visios using Regex Replace vs using Custom Properties
Solved1.51K views29th March 2023Regex server Visio visio properties
Ryan Hepworth [DevOps Advocate]1.55K 20th March 2023 0 Comments
Hi all,
I am trying to build a Visual Overview for the RX1 protocol to display Carrier to Noise Margin, as the IRD has 4 IRDs in one element, I am having to display the C/N Margin for each IRD on one panel.
At the moment I have it built using 4 custom properties but I am looking into the possibility of doing this using Regex Replace.
The 4 custom properties I am currently using simply show the name of each IRD Input (IRD 01, IRD 02 etc) and then C/N is defined in the Property data field from a table.
Would it be more backend/server side heavy to use 4 custom properties or would it more intensive to use a regex replace 4 times in one visio?
Thanks
Ryan Hepworth [DevOps Advocate] Selected answer as best 29th March 2023
Ryan Hepworth [DevOps Advocate]1.55K Posted 29th March 2023 0 Comments
Regex Replace carries less server load (spoke to Skyline)
