Using HTTPS session with invalid/untrusted certificate
Solved1.80K views23rd October 2024Connector HTTPS session TLS
Benjamin Hodžić [SLC] [DevOps Advocate]1.43K 10th October 2024 0 Comments
I'm developing a connector which needs to access an endpoint (TLS secured), where the certificate is not trusted (ERR_CERT_AUTHORITY_INVALID).
On Postman or any of the browsers, a prompt occurs before proceeding to the link, where manual user intervention is required to access the endpoint. Users usually click the "proceed anyway" button only once, and the browsers store users' choices in the future, while still marking the location as unsafe?
My question is: How to get DataMiner to forcefully trust the certificate issued by the host, so that the requests sent through HTTP Sessions start getting responses and behave the same as browsers?
Benjamin Hodžić [SLC] [DevOps Advocate] Selected answer as best 23rd October 2024
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 10th October 2024 3 Comments
Hi Benjamin,
What you could try to do is importing the certificate on the DataMiner server that is hosting the element. This will make the system recognize it as a trusted certificate. The following page explains how you can do that: https://techcommunity.microsoft.com/t5/windows-server-essentials-and/installing-a-self-signed-certificate-as-a-trusted-root-ca-in/ba-p/396105. A server reboot might be required after the import.
Tom Waterbley [SLC] [DevOps Enabler] Posted new comment 23rd October 2024
Benjamin Hodžić [SLC] [DevOps Advocate] commented 11th October 2024
Thanks Tom. I’ll give it a try and report back
Benjamin Hodžić [SLC] [DevOps Advocate] commented 23rd October 2024
just to note, no server reboot was required. Worked instantly!
Tom Waterbley [SLC] [DevOps Enabler] commented 23rd October 2024
Thank you for the update Benjamin. Glad to hear this is solved.
