Using class library for remote element table retrieval?
Solved1.42K views17th March 2022class library
Alex Johnson [SLC] [DevOps Advocate]904 16th March 2022 0 Comments
Hi all,
I was looking at retrieving parameters from a number of remote elements, and was just wondering if using the class library like below was the most efficient way:
It seems to be working efficiently, but we will eventually have this on 60+ elements at a time.
Is this fesabile/the most efficient way to do this?
Alex Johnson [SLC] [DevOps Advocate] Selected answer as best 17th March 2022
Geovanny Galeano [SLC] [DevOps Advocate]800 Posted 16th March 2022 0 Comments
Hi Alex
I don't see nothing wrong with your logic to retrieve parameters from external elements. The best way is to definitely use the class library which you are already doing. One thing you can do is to check for nulls after your dms calls to not continue with the next part if nothing was returned. Also maybe in the GetData method there is an option to pass a filter to only request the columns you need so letting the server handle the filtering rather than you doing that after requesting the entire table.
