Using AutoIncrementFieldDescriptor in a CRUD script
Solved1.84K views13th March 2025DOM CRUD
Felix Wesemeier [DevOps Catalyst]2.54K 26th February 2025 0 Comments
Hi community,
does someone has an example how to create a AutoIncrementFieldDescriptor value  withinin a CRUD script when creating an instance?
My resulting ID has an incrementing part but there is another variable part for the year within the same field: YY/{0:000000000}, e.g. 25/000000123
And I don’t want to hardcode the year.
Felix Wesemeier [DevOps Catalyst] Selected answer as best 13th March 2025
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.79K Posted 6th March 2025 5 Comments
Hi Felix,
You can indeed use the IncrementHelper to get the next value for a given incrementer by ID. When you use the AutoIncrementFieldDescriptor, the same underlying API is used by the DOM manager to get the next value. With this helper, you could build your own incrementing ID by hooking into the ‘create’ actions with a CRUD script and update the DOM instance with your custom ID. Keep in mind though that this does mean every create will result in another update, increasing the load on the system for every create action. As the script is executed asynchronously, you may also have a situation where the ID field would not be populated yet if you for example would create the DOM instance in a form and then have a table refreshed right after the save.
I see in your post that you would prefer to avoid hard-coding the year, but in a way, this does provide a more performant solution in general. A simple script could be made which is run around the new year period with a scheduled task that would update the AutoIncrementFieldDescriptor with the new year every time.
Note that with the CRUD script approach, the same limitation applies here as mentioned in the ‘Important’ section on the docs page for that FieldDescriptor. In some very rare cases where there would be database issues, you may run into having the same ID being returned by that incremementer. We have only seen this issue once in the past, but keep in mind that it would be safer to not have your solution/code rely on these IDs being 100% unique. Ideally, these IDs are used as a visual indication to easily find the DOM instances back, where it would not be a system-breaking issue if two instance would be found in very rare cases.
There are plans to make the AutoIncrementFieldDescriptor obsolete for that exact reason. A new field descriptor may be added in the future instead which also makes it possible to generate a unique human-readable string. (But it won’t be a number incremented by one each time)
Felix Wesemeier [DevOps Catalyst] Posted new comment 14th March 2025
Felix Wesemeier [DevOps Catalyst] commented 12th March 2025
Hi Thomas,
thanks for the idea with the scheduled script to update the field itself.
This works fine.
But I noticed after updating this field, it is the last one in the section (was the first before).
Any way to avoid this?
I used GetAllFieldDescriptors, then AddOrReplaceFieldDescriptor and then Update to write the Field Decriptors to the CustomSectionDefinition
Thomas Ghysbrecht [SLC] [DevOps Enabler] commented 12th March 2025
The 'AddOrReplaceFieldDescriptor' method will indeed remove the existing descriptor (if it exists) first and add it to the list again, resulting in it being the last one.
In theory, if you have retrieved the AutoIncrementFieldDescriptor from the SectionDefinition without cloning the object via LINQ for example (FirstOrDefault), you can just change the 'IDFormat' property of the AutoIncrementFieldDescriptor. The descriptor that you retrieved via 'GetAllFieldDescriptors' is still part of the collection on the SectionDefinition, so after changing the 'IDFormat', you should be able to just pass it to the update method as you already did. The difference thus is not calling the 'AddOrReplaceFieldDescriptor'.
Do you have an example how to get the section without cloning the object?
It's the FieldDescriptor actually that should not be cloned. If you just use LINQ, they won't be cloned, so it's just a matter of not calling 'Clone' yourself. I have made an example that hopefully clarifies how this update can be done: https://github.com/Skyline-ThomasGH/DataMiner_ScriptExamples/blob/main/DOM_UpdateFieldDescriptorProperty.xml
Felix Wesemeier [DevOps Catalyst] commented 14th March 2025
Thanks for providing this example!
It works fine.
Felix Wesemeier [DevOps Catalyst]2.54K Posted 27th February 2025 0 Comments
Is still need to test it but it looks I can use: incrementHelper.AutoIncrementers.GetNextIncrementValue(autoIncrementerID)
Felix Wesemeier [DevOps Catalyst] Answered question 27th February 2025
