Unit Test fails on Jenkins. Could not load file or assembly SLManagedScripting
Solved1.80K views8th January 2024
Julio Riambau [SLC] [DevOps Member]302 8th January 2024 0 Comments
Could you please help me with the following issue?
On Visual Studio 2022 the Unit Tests are passing but in Jenkins the following message is shown.
System.BadImageFormatException: Could not load file or assembly 'SLManagedScripting, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format.
In the test project.
<ItemGroup>
<PackageReference Include="FluentAssertions">
<Version>5.10.3</Version>
</PackageReference>
<PackageReference Include="Moq">
<Version>4.16.1</Version>
</PackageReference>
<PackageReference Include="MSTest.TestAdapter">
<Version>1.3.2</Version>
</PackageReference>
<PackageReference Include="MSTest.TestFramework">
</PackageReference>
<PackageReference Include="Skyline.DataMiner.Core.DataMinerSystem.Common">
<Version>1.1.1.4</Version>
</PackageReference>
<PackageReference Include="Skyline.DataMiner.Core.DataMinerSystem.Protocol">
</PackageReference>
<PackageReference Include="Skyline.DataMiner.Dev.Protocol">
<Version>10.4.1.2</Version>
</PackageReference>
<PackageReference Include="Skyline.DataMiner.Files.SLManagedScripting">
</PackageReference>
<PackageReference Include="StyleCop.Analyzers">
<Version>1.1.118</Version>
<IncludeAssets>runtime; build; native; contentfiles; analyzers; buildtransitive</IncludeAssets>
<PrivateAssets>all</PrivateAssets>
</PackageReference>
</ItemGroup>
could you please point me in the right direction?
thanks in advance.
Julio Riambau [SLC] [DevOps Member] Selected answer as best 8th January 2024
Geovanny Galeano [SLC] [DevOps Advocate]820 Posted 8th January 2024 2 Comments
Issue was resolved by updating the GIT system files via the SLC repo manager.
Geovanny Galeano [SLC] [DevOps Advocate] Posted new comment 15th November 2024
Ola Mohamed [DevOps Advocate] commented 15th November 2024
Hello Geovanny, I have the same error but I fond that SLC repo manager is only for Skyline employees, So how can I solve this error?
Geovanny Galeano [SLC] [DevOps Advocate] commented 15th November 2024
Hi Ola, could you post a new question and link this one in the description. Someone should be able to answer it. Im assuming you can also add the files manually but I'm not 100% sure of the configuration.
