Triggering IAS from element via LCA leads to script not attaching
Solved346 views4th February 2026IAS LCA protocol.ExecuteScript
Bautista Solanet [SLC] [DevOps Advocate]838 29th January 2026 0 Comments
Hello Dojo,
I have a driver that triggers an IAS by pressing a button, it works when I test it on Cube, but when I try to run it from LCA or the web monitoring app, the script does not attach at all. I'm wondering if anybody else has had this issue.
Thank you,
Bauti
Bautista Solanet [SLC] [DevOps Advocate] Selected answer as best 4th February 2026
Peter Vanpoucke [SLC] [DevOps Advocate]1.23K Posted 3rd February 2026 0 Comments
Hi Bauti
An interactive client can only be located and attached through Cube. This isn’t supported when the trigger comes from a web app.
If you’re working in a web application, you’ll need to launch the interactive script directly rather than relying on the client‑lookup mechanism.
Kind regards
Peter
