Triggering context menu parameter from Automation Script
Solved2.31K views28th November 2023automation scipt ContextMenu
8
Dario Sarkanovic [SLC] [DevOps Advocate]1.20K 28th November 2023 0 Comments
Driver has context menu parameter for add/delete channels from table. That’s only way how channel can be added or deleted from driver.
I know that we can do SetParameter() from automation script and it will trigger QA if value is changed but QAction that are triggered from context menu has additional contextData object.
Is it possible to change value and trigger that context menu parameter from automation script?
Dario Sarkanovic [SLC] [DevOps Advocate] Selected answer as best 28th November 2023
Simon Vandamme [SLC] [DevOps Advocate]1.02K Posted 28th November 2023 0 Comments
Hi Dario,
The best way to achieve what you are trying to do is to do it via InterAppCalls. This way both the automation script(s) and the context-menu can make use of the same InterAppCalls. Your context-menu QAction will then only contain the code responsible for converting contextMenuData into an InterAppCall.
How to implement contextMenu => Use the related NuGet: NuGet Gallery | Skyline.DataMiner.Utils.Table.ContextMenu 1.0.0.1
More info on InterAppCalls => InterApp classes | DataMiner Docs
regards,
Simon Vandamme [SLC] [DevOps Advocate] Edited answer 28th November 2023
9
João Severino [SLC] [DevOps Enabler]14.78K Posted 28th November 2023 3 Comments
Hi Dario,
You should be able to use the snippet from the answer to this other question
automation script: context menu – DataMiner Dojo
Dario Sarkanovic [SLC] [DevOps Advocate] Unselected an answer 28th November 2023
Simon Vandamme [SLC] [DevOps Advocate] commented 28th November 2023
if the context-menu code already exists, this solution is indeed a quick win.
But if you need to create something new, I would really suggest to go for the InterAppCalls approach which is to me much more elegant, future proof, flexible.
João Severino [SLC] [DevOps Enabler] commented 28th November 2023
Indeed, this approach is best when adapting the connector is not possible or should be avoided because it requires no changes to the existing logic.
But since the suggestion on the other question uses an SLNet call the usual disclaimer applies here where SLNet calls should be used only when strictly necessary.
Dario Sarkanovic [SLC] [DevOps Advocate] commented 28th November 2023
Hi Joao and Simon, in my case context menu logic already exist. Will try with that solution. But it’s also good to know that when we implement these things from scratch it will be good to use InterAppCalls.
