Trending not working properly / average values not displayed
Solved2.36K views19th February 2024average trending real time trending trending trending data Trending monitoring
Nils Hoven [DevOps Advocate]1.55K 31st January 2024 0 Comments
we are using self-developed drivers / connectors for some elements which have only a limited and simple set of parameters. For some of these parameters we have trending activated in a trend template (real-time & average). But all we see is the real-time trend data, and no long term average data.
In the system settings we've set the TTL of the real-time trend data to 2 days (instead of default 1 day), and this has an effect on the trend graph as expected!
What may be the root cause for the missing average trend data? We've already checked the driver implementation and compared it to other drivers, also self-developed, where trending is working just fine.
Any ideas where to look at? Thank you very much! 🙂
Edit:
Nils Hoven [DevOps Advocate] Selected answer as best 19th February 2024
Matthias Declerck [SLC] [DevOps Advocate]2.99K Posted 31st January 2024 3 Comments
H Nils,
Thank you for reaching out to us.
How is the trending template defined on your connectors?
Could you verify that the average trending is enabled?
Example:
Other way to configure it is when drill down on the parameter and go to the templates tab.
Example:
Also, can you see the trending icon or an arrow on your trended parameters in the element data display?
Example:
Hope this helps you further.
Nils Hoven [DevOps Advocate] Unselected an answer 19th February 2024
Nils Hoven [DevOps Advocate] commented 31st January 2024
Hi Matthias,
thank you for your input! Both is the case. I’ve added two more screenshots in the initial question to show that the configuration seems to be valid…
BR
Nils
Matthias Declerck [SLC] [DevOps Advocate] commented 1st February 2024
Hi Nils. I think it would be better now is to create a support ticket as it is not straight forward to pinpoint the root cause of the problem you encountered.
Nils Hoven [DevOps Advocate] commented 1st February 2024
Hi Matthias,
I’ve just created a support ticket. Thank you!
BR
Nils
