TreeControls: Default level of collapse
Solved719 views2nd June 2025TreeControl
Joshua Wong [SLC] [DevOps Advocate]649 2nd April 2025 0 Comments
I was wondering if it is possible to expand a treecontrol to collapse to a certain level? So I was hoping to open the page and default to seeing the following level of collapse.
Thanks!
Joshua Wong [SLC] [DevOps Advocate] Selected answer as best 2nd June 2025
Jeroen Neyt [SLC] [DevOps Advocate]2.53K Posted 15th April 2025 0 Comments
At the moment, this isn't possible but we love to hear your thoughts! Feel free to create a feature suggestion to see if other people in the community might find this useful as well.
