Thread problem in SLProtocol: TimerThread
Solved3.63K views16th September 2020protocol RTE
Mieke Dryepondt [SLC] [DevOps Advocate]4.27K 1st July 2020 0 Comments
What are the possible causes of a Timer Thread RTE when all of the timers content are poll-groups?
In this case serial polling is done and a condition is defined on the timer.
Normally the timer will move the poll-groups on the execution queue that is running in the protocol thread. In case executing the group would take too long I would expect a Protocol Thread RTE, not a Timer Thread RTE. So when can this occur?
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 16th September 2020
João Severino [SLC] [DevOps Enabler]14.78K Posted 1st July 2020 0 Comments
If I look at a protocol pending call, the timer thread remains in there until the last group it set to execute is finished.
If I recall correctly this is used as a flag so that the timer knows it can start another iteration of adding groups to execute.
João Severino [SLC] [DevOps Enabler] Answered question 1st July 2020
