Syslog messages element configuration
Solved1.22K views5th February 2025connection Connector
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K 4th February 2025 0 Comments
I’m looking into the WISI Tangram connector, I see it has a SysLog connection. I tried to activate this by putting in the device IP into that connection during the element creation. But the messages weren’t arriving to the element. I then filled in “any” as IP address and this worked, so the messages were arriving and filling in the table in the connector, this is fine for staging but I think that all syslog messages are now arriving in this element. What could cause this behavior? and what could I do to overcome this? (I’m also sure that these are the messages from that IP are the coming into that element as they match with with wireshark)
PS I know there is a Generic syslog Receiver connector, but i can’t get that one to work.
Timothy Van Poucke [SLC] [DevOps Advocate] Selected answer as best 5th February 2025
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K Posted 5th February 2025 0 Comments
Eventually i found the answer: I had to add the smartIpHearer, and then filter it in the driver.
Flavio Meneses [SLC] [DevOps Enabler]1.33K Posted 4th February 2025 2 Comments
Hi Timothy,
I suspect that the connection is a smart-serial one and that you want to use it as a server. Therefore, you need to define the address you want DataMiner to listen to. If “any” is specified, DataMiner will listen to all host addresses.
If you want to filter the addresses that your element communicates with, you can use the Accepted IP Address setting (docs).
Hope this helps!
Flavio Meneses [SLC] [DevOps Enabler] Posted new comment 5th February 2025
Timothy Van Poucke [SLC] [DevOps Advocate] commented 5th February 2025
That doesn't work as it is restricted to TCP while Syslog is UDP
Flavio Meneses [SLC] [DevOps Enabler] commented 5th February 2025
Correct, I overlooked that the Accepted IP Address property is only valid for TCP connections.
