Stuck alarm on DMS: how to solve?
Solved2.27K views14th December 2023alarm alarm stuck DMA lost connection stuck alarm
Nils Hoven [DevOps Advocate]1.82K 13th December 2023 0 Comments
our active failover DMA lost the connection to the other DMA because of some network maintenance. Everything resolved and is fine, and both DMAs communicate properly with each other. However, there is an alarm stuck on the active DMA in the alarm table:
So far I cannot find a way to get rid of this stuck alarm.
  • Right click -> no options available.
  • Restarting Cube -> no effect.
  • Restarting the other DMA, to provoke the alarm to occur again and resolve itself -> no effect.
Any suggestions? Is a restart of the DMA itself neccessary?
Thank you very much! 🙂
Nils Hoven [DevOps Advocate] Selected answer as best 14th December 2023
Nils Hoven [DevOps Advocate]1.82K Posted 14th December 2023 0 Comments
In the end, it is a DMA restart that solves the issue.
