Stream Viewer – Reason for Error : 6. [default]
Solved1.89K views25th August 2021Connector HTTP protocol stream viewer
David Pernes [SLC]90 24th August 2021 0 Comments
I'm getting the following error on Stream Viewer which i'm not able to understand what would be the root cause of it.
This is an HTTP Connector sending calling a Group to execute a HTTP Session.
David Pernes [SLC] Selected answer as best 25th August 2021
Stijn Declerck [SLC] [DevOps Advocate]824 Posted 25th August 2021 1 Comment
Hi David,
I recently encountered the same issue and also posted a question on this. Here is the link: https://community.dataminer.services/question/response-error-6/
David Pernes [SLC] Posted new comment 25th August 2021
David Pernes [SLC] commented 25th August 2021
thanks the stated link does provide a great explanation.
