SRM: How do you run an automation script when a booking starts?
Solved2.58K views20th May 2021Automation MDC service definition SRM
Cyrus Uible [SLC]40 20th May 2021 0 Comments
Use case:  We are using Process Automation to automatically deploy permanent bookings.  When the booking starts I want to run an automation that feeds in the ServiceID of the booking (or the ReservationID which I can use to get the ServiceID).  Tried using the "Created Booking Action" property on one of the nodes in the service definition, but this runs too early, as the booking\service isn't fully formed yet.  Is there another property I can use somewhere that will only run once the booking actually starts?
Cyrus Uible [SLC] Selected answer as best 20th May 2021
Robin Meurisse [SLC] [DevOps Advocate]1.43K Posted 20th May 2021 0 Comments
Hi Cyrus,
The custom script can also be triggered on the pre-roll or start actions of the booking.
On the service definition, we can specify actions. These actions can correspond to the pre-roll, start, stop and post-roll events.
The action script is called an LSO script or life-cycle service orchestration script referring to the start/stop/pre-roll/post-roll actions. The SRM package comes with a LSO script template that can serve as an entry point to run your custom actions. You can find the template under Automation > 'SRM_LSOTemplate'.
Kind regards,
Robin
Robin Meurisse [SLC] [DevOps Advocate] Answered question 20th May 2021
