Spectrum Analyser markers in an automation script
Solved2.28K views12th April 2023automation scipt spectrum analyzer
MAXIMILIANO FILHO [DevOps Enabler]1.10K 10th January 2023 0 Comments
Hello!
Is it possible, using an automation script, to create markers in the Spectrum Analyzer and collect measurements from them?
Thanks in advance
MAXIMILIANO FILHO [DevOps Enabler] Selected answer as best 12th April 2023
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 11th January 2023 0 Comments
Hi Maximiliano,
If you want to do some automation with Spectrum elements, you may want to work with Spectrum analyzer scripts and monitors | DataMiner Docs ?
Hope this helps you further.
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 11th January 2023
