Smart Serial Port not being claimed by Element
Solved3.59K views4th November 2021SLPort SmartSerial
Jack Perrott-Webb52 24th June 2021 0 Comments
We have configured our element to listen on a smart serial port, but it does not seem to be receiving data. The device that posts to this port has errors of "No connection could be made because the target machine actively refused it".
Looking on the machine itself, I can see that the port is not open (using Resource Monitor), but all 5 instances of SLPort are running and no apparent errors in the logs.
Where would you start to investigate? Please note that it will be very challenging to install wireshark so any other suggested tips would be appreciated (but if this is the only way then so be it).
Recently upgraded from DM9.6.10 to DM10.1 CU2 (unsure if related, but other environments do not have the above issue)
Jack Perrott-Webb Selected answer as best 4th November 2021
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K Posted 24th June 2021 2 Comments
Investigation showed the port was in use by another non-DataMiner process running on that server.
Jack Perrott-Webb commented 24th June 2021
Yes, for fuller detail for someone finding this later, there was a confusion by another team between the netstat report of active ports and the Resource Monitor’s list of listening ports. This additional application had an established connection on this port range (hence not appearing as listening). Setting the smart serial temporarily to a different port showed that it was then listening without issue. We were confused for a long time as there was nothing suggesting that we had failed to grab the port (even SLDataMiner suggested the log had been successfully claimed).
Lessons learned:
1) Netstat > Resource Monitor
2) Add debug messages to logs where possible to confirm the acquisition of ports
3) Make sure applications in general use reserved ports only rather taking any old thing!
Jeroen Neyt [SLC] [DevOps Advocate] commented 25th June 2021
FYI, for future references:
SLPort logs the following on debug level 1 when it can’t bind to the port:
“Finished connect thread. bind failed.10048”
Where error code 10048 translates to WSAEADDRINUSE. This error occurs if an application attempts to bind a socket to an IP address/port that has already been used for an existing socket, or a socket that was not closed properly, or one that is still in the process of closing.
