setting up DMS with StaaS
Solved1.11K views27th February 2024DMS STaaS
Tim Vandenbruwaene [SLC] [DevOps Member]2.24K 27th February 2024 0 Comments
So I have 2 brand new DataMiner agents that I want to put in a cluster and connect to STaaS.
What's the best way to move forward?
1) Setup the DMS and connect then to STaaS
2) Connect a single DMA to STaaS and then add the other DMA to the DMS like described in :
Adding a DataMiner Agent to a DMS running STaaS | DataMiner Docs
3) ...
Tim Vandenbruwaene [SLC] [DevOps Member] Selected answer as best 27th February 2024
Ruben Devos [SLC] [DevOps Member]127 Posted 27th February 2024 0 Comments
Hi Tim,
If neither of the agents are using STaaS as their database, it will probably be the easiest to first cluster them and then connect the cluster to STaaS according to this documentation
If one of them is already connected to STaaS then you'll need to followed the documentation you linked.
