Serial connector for USB device
Solved2.84K views15th June 2021Connector serial
Robbie Demaegdt [SLC] [DevOps Member]666 10th June 2021 0 Comments
Is it possible to create a serial connector that will interface with a device connected by USB to the dataminer server?
Robbie Demaegdt [SLC] [DevOps Member] Selected answer as best 15th June 2021
Leander Druwel [SLC] [DevOps Member]2.10K Posted 10th June 2021 2 Comments
Hi Robbie,
Not sure about this, but I believe a USB gets mapped to a COM number on the server when plugged in. That is also visible in the Device Manager when plugging in the USB.
The COM is then also available as Serial port into the wizard. I did not test if communication works through this though.
Leander Druwel [SLC] [DevOps Member] Posted new comment 11th June 2021
Robbie Demaegdt [SLC] [DevOps Member] commented 10th June 2021
Yeah I know about the COM port but I have no idea if the bus address has to be filled in.
The other settings can be found in the device manager but I don’t get any responses.
Currently my bus address is empty because I can’t fill in a string value (COM3).
Leander Druwel [SLC] [DevOps Member] commented 11th June 2021
Ok, guess that you’re quite close then. To me, using a bus address would not really make sense, as you’d only expect a single unit on the serial connection. Others can surely jump in here if we would have used that in the other connectors.
