Script execution error System.TypeLoadException
Solved2.29K views13th December 2023interactive automation script
Vincenzo Converso [DevOps Member]92 13th December 2023 0 Comments
I've tried to do the Kata 10: Create a simple interactive script but when i try to execute i have this error:
Script Failure (Mask Element): System.TypeLoadException: Unable to load the 'Text' type from the assembly 'SLManagedAutomation, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'.
in CManagedAutomation.RunWrapped(CManagedAutomation* , Int32 iCookie, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* pvarReturn, String scriptName)
in CManagedAutomation.Run(CManagedAutomation* , Int32 iCookie, Char* bstrScriptName, IUnknown* pIAutomation, tagVARIANT* varParameters, tagVARIANT* varEntryPoint, tagVARIANT* pvarReturn, tagVARIANT* pvarEntryPointResult) (CSharp; 0x80004005h): (see comment for more details)
If needed this is the code https://github.com/ConversoVincenzo/Kata10.git and these are the versions:
Skyline.DataMiner.Core.DataMinerSystem.Automation version 1.1.1.3
Skyline.DataMiner.Dev.Automation version 10.3.12.2
Skyline.DataMiner.Utils.InteractiveAutomationScriptToolkit version 7.0.2
Vincenzo Converso [DevOps Member] Selected answer as best 13th December 2023
João Severino [SLC] [DevOps Enabler]14.78K Posted 13th December 2023 5 Comments
Hi Vicenzo,
I had a look into your code and tested locally and I did not experience any issues as you did.
Could you let us know which version of DataMiner you are running as well as which version of DIS you have installed?
*EDIT*
By navigating to the about option you should be able to see the DataMiner version
Vincenzo Converso [DevOps Member] Posted new comment 13th December 2023
Vincenzo Converso [DevOps Member] commented 13th December 2023
My DIS Version is 2.45.1.8 and my DMA version is 10.3.2243.21550
João Severino [SLC] [DevOps Enabler] commented 13th December 2023
I cannot immediately determine the DMA version from the value you are giving me
Could you check my edited answer on how to get the DMA version in Cube?
10.3.0.0-13537-CU9
Given that DataMiner version, I believe the issue lies with the version of the InteractiveAutomationScriptToolkit you are currently using.
There are currently 3 main ranges for that library and have the following supported DataMiner versions
5.0.X -> 10.1.10 and above
6.X.X -> 10.3.1 and above
7.0.X -> 10.3.7 and above
As shown above, range 7.0.X is only compatible with 10.3.7 and above, and because you are using DataMiner Main Release of 10.3.0 CU9, I would try one of the other ranges to see if works fine for you.
6.1.X may work but if not 5.0.X should do the trick.
P.S. Do note that you will also need to lower the version of Skyline.DataMiner.Dev.Automation NuGet to the one compatible with your DataMiner version (in your case 10.3.0.9)
Thank you, i was in the process of updating my DMA to the latest version and now the script works fine. So i suppose the problem was related to the version as you suggested.
