Script alternative for protocol.GetKeysForValue
Solved337 views5th February 2026#automationscripts table
Ryan Hepworth [DevOps Advocate]1.55K 25th November 2025 0 Comments
Hi All
As the above says, I am trying to find an alternative to protocol.GetKeysForValue that can be used in an automation script to check a column of a table for a value and retrieve the primary key or display key that matches the value.
Thanks
Ryan
Ryan Hepworth [DevOps Advocate] Selected answer as best 5th February 2026
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 26th November 2025 0 Comments
Hi Ryan,
There’s no built-in GetKeysForValue() method available in an automation script, but you can achieve this using a small helper method, for example:
public ICollection<string> GetKeysForValue(Element element, int tablePid, int columnPid, object value)
var keys = new List<string>();
foreach (var key in element.GetTablePrimaryKeys(tablePid))
var cellValue = element.GetParameterByPrimaryKey(columnPid, key);
if (Equals(cellValue, value))
keys.Add(key);
return keys;
Usage:
var element = engine.FindElement("element name");
var keys = GetKeysForValue(element, 1000, 1003, "my value");
Kind regards,
Tom
