Scheduler and Failover
Solved515 views4th July 2025
Lisa Reed [DevOps Advocate]110 3rd July 2025 0 Comments
Hi, we have noticed that after a failover the Scheduler is no longer able to retrieve the 'Last Runtime Result' of tasks that were performed on the other agent in the pair. I would just like to confirm if this is the expected behaviour? Thanks in advance!
Lisa Reed [DevOps Advocate] Selected answer as best 4th July 2025
Pieter Carlu [SLC] [DevOps Advocate]260 Posted 4th July 2025 0 Comments
Hi Lisa,
Yes, this is expected behavior. The last run time and result are not stored in DataMiner but in Windows Task Scheduler. Therefore, the information shown in the Scheduler module comes directly from the Windows Task Scheduler of the online failover agent and reflects the last time the task ran on that specific agent.
