Scalable applications: Best way to fetch an table from an element in ad hoc
157 views19th March 2026ad-hoc optimizing Tables
Gerwin van der Kamp [DevOps Advocate]3.77K 19th March 2026 0 Comments
What is the fastest way to fetch an table from an element in an ad-hoc datasource, and if possible have it support realtime updates.
Use-case: Transform an collumn within the table to an table used for node-edge component
Gerwin van der Kamp [DevOps Advocate] Edited question 19th March 2026
