Running Crowdstrike on DMAs and Cube client machines
Solved2.52K views6th July 2023Crowdstrike DMA
Dave Keller [DevOps Enabler]1.91K 11th March 2022 0 Comments
Our InfoSec team are requesting that we install CrowdStrike Falcon on our DMAs and Cube machines.
I can see that this question has been asked before (Crowdstrike - DataMiner Dojo), though the answer doesn't actually state what exceptions/adjustments are required to be able to run Crowdstrike.
Can anyone advise?
Dave Keller [DevOps Enabler] Selected answer as best 6th July 2023
Joao Candeias [SLC] [DevOps Member]129 Posted 11th March 2022 0 Comments
Hi Dave supplementing Edson's comment please have also a look on how we detect the SL* processes interference from various antivirus applications on the link below:
https://community.dataminer.services/documentation/check-antivirus-dlls/?hilite=%27antivirus%27
CrowdStrike included.
("BPA test is available on demand. You can run it in System Center (on the Agents > BPA tab, available from DataMiner 9.6.0 CU23, 10.0.0 CU13, 10.1.0 CU2 and 10.1.4 onwards). From DataMiner 10.1.4 onwards, it is available by default.")
Kind regards
Joao Candeias [SLC] [DevOps Member] Answered question 11th March 2022
