Routerpanel XAML compare values of binding and connection binding
Solved1.88K views21st September 2022router control xaml
Gerwin van der Kamp [DevOps Advocate]4.09K 25th July 2022 0 Comments
Is it possible with the router panel to compare the value of a binding to an value of an connections binding?
What i try to achieve is that when the {binding Index} and {Binding Connections[0].Model.Index} doesn’t match it will trigger an other background colour of my output button.
Gerwin van der Kamp [DevOps Advocate]4.09K Posted 20th September 2022 0 Comments
for future reference: there is an github with an routercontrol button design:
https://github.com/bertbsky/RouterControlButtonDesigner
Which now includes a few examples of converters as well:
https://github.com/bertbsky/RouterControlButtonDesigner/blob/master/CustomTheme.xaml
