Retrieving user Guid from an Automation Script
Solved2.35K views17th November 2021Automation script hyperlink
Tiago Bento [SLC]20 17th November 2021 0 Comments
Hi all,
Is it possible to retrieve the Guid for the user triggering an automation script?
This script is going to be launched from the context menu of an Alarm if that helps.
Thanks in advance.
Tiago Bento [SLC] Selected answer as best 17th November 2021
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 17th November 2021 0 Comments
Hi Tiago,
The Engine class has a method called GetUserConnection(), which stores connection info.
This includes the Connection ID and the user name.
Help link: https://help.dataminer.services/dataminer/#t=DataMinerUserGuide%2Fpart_7%2FCsharpReference%2FEngine_methods.htm
Hope this helps you further
