Rertieve a parameter from another element in a protocol C# QAction
322 views2nd December 2025
Dominique Bodart [DevOps Member]783 2nd December 2025 0 Comments
In a protocol, I need to retrieve the value of a parameter from another element than the one where the QAction is written. I try to use something as follow which works in an Automation script but using a "GetParameter" instead of SetParameter:
Element element = engine.FindElement("RFSW GS02 SA J5");
if (element != null) {
//Set the connectedInput value (parameter id 1012) to 6 (port number)
pos = Convert.ToString(element.GetParameter(1012));
But if I use this script in the QAction of the driver I am writing, it generates an error, saying there is no "Element" class. So I guess there is something missing. Is there any solution?
Thank you,
João Severino [SLC] [DevOps Enabler] Answered question 2nd December 2025
João Severino [SLC] [DevOps Enabler]14.47K Posted 2nd December 2025 5 Comments
Hi Dominique,
The Element class is specific to the automation scripts (see reference), an alternative you can use is the IDmsElement object from the Class Library and your code would look something like
var idms = protocol.GetDms();
var element = idms.GetElement("RFSW GS02 SA J5");
var posParameter = element.GetStandaloneParameter<string>(1012));
var pos = posParameter.GetValue();
To learn more about the Class Library, you can check this docs page: About the class library | DataMiner Docs
Hope this can help
Dominique Bodart [DevOps Member] Posted new comment 4th December 2025
Dominique Bodart [DevOps Member] commented 2nd December 2025
Thank you João,
Nearly there, I thing. The following script still returns with one error on first line:
var posParameter = element.GetStandaloneParameter<string>(1012);
Error: CS1061 'SLProtocol' does not contain a definition for 'GetDms'
Do I need to add some library or something like that?
João Severino [SLC] [DevOps Enabler] commented 2nd December 2025
Yes, you need to install the NuGet from https://www.nuget.org/packages/Skyline.DataMiner.Core.DataMinerSystem.Protocol
Dominique Bodart [DevOps Member] commented 3rd December 2025
Noted. But if there is a Dataminer update later on, will it take into account the update of the NuGet package, if needed?
João Severino [SLC] [DevOps Enabler] commented 3rd December 2025
We try to make sure those NuGets are always forward-compatible and that DataMiner does not introduce breaking changes to those.
However, upgrading your DataMiner will not automatically upgrade the NuGets, that remains a manual action.
Dominique Bodart [DevOps Member] commented 4th December 2025
Hi João,
Understood. Lany thanks for your kind support 🙂
