Rendering issue for SVG icons
Solved813 views9th October 2024Visual Overview
Bing Herng Chong [SLC] [DevOps Advocate]1.54K 24th September 2024 0 Comments
There has been a number of new icons introduced to Skylicons that would make for compelling Visual Overview diagrams. But rendering issues were observed that are already reported here: https://community.dataminer.services/question/visio-why-is-my-svg-icon-not-shown-correctly
Is there already a fix implemented and if so what version of DataMiner contains this fix?
The user I'm designing Visual Overview for is currently on DataMiner 10.3.0 CU7. If there is not yet a fix implemented, I suppose the alternative is to use PNG over SVG. Is there a way to make PNG more compatible with dark mode?
Bing Herng Chong [SLC] [DevOps Advocate] Selected answer as best 9th October 2024
Pieter Van Compernolle [SLC] [DevOps Enabler]3.81K Posted 25th September 2024 1 Comment
Hi Bing,
I did a brief investigation on the updated Skylicons. Seems like they hold a lot of Bezier curves which have limited support currently in the Cube Visio rendering. Since we already support Bezier curves in general, there is probably something we can do to make the Skylicons render better in Cube. I have created a task for it [DCP249509].
Bing Herng Chong [SLC] [DevOps Advocate] Posted new comment 9th October 2024
Bing Herng Chong [SLC] [DevOps Advocate] commented 9th October 2024
Thanks Pieter for putting this on the radar.
