removing alarms of a specific element from DataMiner manually
Solved1.87K views12th January 2023alarm data database
Srikanth Mandava [SLC] [DevOps Advocate]936 28th June 2021 1 Comment
Is there a mechanism to remove the selected alarms manually from the dataminer manually. TTL configuration is available but this is a global setting rather than a alarms related to a specific element that may have created a huge amount of valid alarms.
Srikanth Mandava [SLC] [DevOps Advocate] Selected answer as best 12th January 2023
Srikanth Mandava [SLC] [DevOps Advocate] commented 30th June 2021
If removing the data per element is not the best practice then that’s completely acceptable. Just need to understand the best way of handling a single or few elements spewing lot of alarms that may not be providing value.
Rodrigo Salvador [SLC]50 Posted 1st July 2021 1 Comment
Hi Skrikanth,
If one or few elements are causing a lot of "useless" alarms, it's always possible to create a new alarm template (which either ignores or filters those alarmed parameters) and assign that special template individually to the elements in question.
Another option is to change the thresholds of the alarms, as well as hysteresis, so that the alarm does not get generated immediately after a value crosses the threshold, but rather waits some time before doing so, thus removing a lot of alarms due to "bouncing" values coming above and below the set thresholds.
Cheers!
Srikanth Mandava [SLC] [DevOps Advocate] commented 6th July 2021
Thanks Rodrigo, this certainly helps to reduce the impact of DataMiner having too many alarms for a particular element. However my question is more specific to pruning the alarms from the database so that we can clear the unnecessary data in the database ahead of TTL configuration kicks in.
