Read parameters for DataMiner DCF Tables
Solved2.77K views10th December 2020Dashboards DCF Visual Overview
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.61K 10th December 2020 0 Comments
Hello everyone,
When trying to include DCF tables in a Dashboard or Visual Overview, it always gives me the possibility to perform writes.
Given the overview of the parameter IDs of the DCF tables in the DDL, do these parameters also have corresponding read parameters? If so, I could probably include these read parameters in the Dashboard or Visual Overview, preventing users to perform writes.
Jan-Klaas Kesteloot [SLC] [DevOps Advocate] Selected answer as best 10th December 2020
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 10th December 2020 0 Comments
Makes sense indeed to have a 'read-only' version of your table in dashboards. With GQI you can already get there, I believe. GQI even allows you to filter out rows and columns in an easy way.
At this moment, no alarm coloring will be applied in GQI tables, but that's on the roadmap (currently forecasted for 10.1.4)
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 10th December 2020
