Read and update View Property through automation script
Solved2.35K views29th March 2024Automation view properties
Michael Kotsias [DevOps Advocate]178 25th March 2024 2 Comments
Dear dojo,
I'm creating an automation script where i read a view Property through
IDms dms = engine.GetDms();
IDmsView myView = dms.GetView(Convert.ToInt16( viewid ));
IDmsViewProperty myViewProperty = myView.Properties.SingleOrDefault(x => x.Definition.Name == "myPropertyName");
This part is fine but when i try to update the Value with
myViewProperty.Value = "new value";
i get the message "myViewProperty.Value cannot be assigned to -- it is read only"
I'm able to assign a value manually. So i don't understand why this property should be read only.
Is there a way to manipulate this?
Thanks
Michael Kotsias [DevOps Advocate] Posted new comment 29th March 2024
Tom Waterbley [SLC] [DevOps Enabler] commented 29th March 2024
Hi Michael. Based on this question and other feedback, we decided to make setting properties on elements, services and views a bit more intuitive. The property object now contain IsWritable and AsWritable methods, which replace the cast to IWritableProperty. This has been implemented in version 1.1.1.8 of the DMS library.
Michael Kotsias [DevOps Advocate] commented 29th March 2024
Hi Tom,
Cool! This makes sense. Thank you for information.
Michael Kotsias [DevOps Advocate]178 Posted 25th March 2024 1 Comment
The trick to cast the property did the job even on my view property.
Thank you very much!
Tom Waterbley [SLC] [DevOps Enabler] Posted new comment 25th March 2024
Tom Waterbley [SLC] [DevOps Enabler] commented 25th March 2024
Glad to hear it did the trick!
