Hello Dojo,
DMA version: 10.4.0.0-CU7
Can I check if I do DELT export the element with child DVEs, will the export automatically delete the DVEs and only collect the parent element?
From the log, when I did the export, I see that DVEs were being deleted.
After import, the DVEs are missing and not being created.
In addition, in the table where DVEs are enabled, the settings are all disabled as well.
Thank you for the help in advance.
Min Thant Aung [SLC] [DevOps Advocate] Asked question 5th August 2025
