[Python, SQLAlchemy] Scripted connectors perform SQL queries
Solved1.07K views9th September 2024python Scripted Connectors sql query SQLAlchemy
Ömer Eryaman [DevOps Member]719 9th September 2024 0 Comments
Hello,
Is it possible to use ‘scripted connectors’ to perform SQL queries via the SQLAlchemy library?
If yes, how can the library be added?
Thank you!
Ömer Eryaman [DevOps Member] Selected answer as best 9th September 2024
João Severino [SLC] [DevOps Enabler]14.48K Posted 9th September 2024 3 Comments
Yes, it should be possible for you to perform SQL queries via your scripted connectors Pythons script.
As long as you can do it in Python it is only then a matter of installing the necessary dependencies as described here Installing extra Python packages | Getting started with the Data Sources module | DataMiner Docs
Ömer Eryaman [DevOps Member] Posted new comment 9th September 2024
Ömer Eryaman [DevOps Member] commented 9th September 2024
Thank you, but do I need to transform the query into JSON?
I ask because on the webpage, it says I need JSON format to parse or display the data in Dataminer.
https://community.dataminer.services/scripted-connectors-are-here/?hilite=scripted+connectors
João Severino [SLC] [DevOps Enabler] commented 9th September 2024
Yes, Scripted Connectors communicates with DataAPI which expects a JSON format.
You will then need to convert whatever result your library gives you into a JSON object like you can see in the examples of this page: https://docs.dataminer.services/user-guide/Advanced_Modules/Data_Sources/Data_API.html
Thanks I understand
