Process Automation – How to configure a repeat gateway?
Solved2.34K views13th December 2022PA process automation repeat gateway
Sebastian Ulloa [SLC] [DevOps Advocate]2.30K 7th December 2022 0 Comments
Is the purpose of the repeat gateway to execute a script until a certain condition meets? If so, what's the way of configuring the gateway?
I was thinking about creating a script that executes the necessary logic and then checks if a parameter was changed or not. If the parameter didn't change, the logic will get execute it again.
But how this would be different from a script task that has that same logic?
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 13th December 2022
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 13th December 2022 2 Comments
Sebastian,
In case you want a process to be run on a regular basis, you should use the Timer Start Event or external code to push tokens in the process.
Repeat gateway can be used inside the process itself. When a token arrives on such a gateway, it will generate one or multiple tokens based on the repeat rule you've defined. Repeat rule is defined in a profile instance:
  • PA GW Repeat Type :
    • limited : limited number of tokens will be generated ( TotalAmount and Interval must be populated)
    • time-limited : tokens will be generated during a period of time ( Interval and Duration must be populated)
    • unlimited : tokens will be generated forever (Interval must be populated)
  • PA GW Repeat TotalAmount
  • PA GW Repeat Interval
  • PA GW Repeat Duration
Emmanuel Dal [SLC] [DevOps Member] Posted new comment 13th December 2022
Sebastian Ulloa [SLC] [DevOps Advocate] commented 13th December 2022
Thank you for the update, Emmanuel.
That’s very interesting and if I understand it correctly, the gateway itself does not contain any logic associated like a scrip task does, but instead its only purpose is to generate multiple tokens.
Emmanuel Dal [SLC] [DevOps Member] commented 13th December 2022
that’s correct!
