Process Automation – How to configure a repeat gateway?
Solved2.58K views13th December 2022PA process automation repeat gateway
Sebastian Ulloa [SLC] [DevOps Advocate]2.34K 7th December 2022 0 Comments
Is the purpose of the repeat gateway to execute a script until a certain condition meets? If so, what's the way of configuring the gateway?
I was thinking about creating a script that executes the necessary logic and then checks if a parameter was changed or not. If the parameter didn't change, the logic will get execute it again.
But how this would be different from a script task that has that same logic?
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 13th December 2022
Emmanuel Dal [SLC] [DevOps Member]4.65K Posted 7th December 2022 1 Comment
Hi Sebastian, could you describe your use case in more details?  Depending on the use case, it is sometimes easier to embed the 'retry' logic in the script task.
Sebastian Ulloa [SLC] [DevOps Advocate] Posted new comment 7th December 2022
Sebastian Ulloa [SLC] [DevOps Advocate] commented 7th December 2022
More than a use case, I’m generally curious about the repeat gateway functionality.
From your comment, I understand that not all repetitive logic should fall under this function type, but which is scenario that this should be used?
