Percetage Numbers Using Wrong Decimal Place on Dashboard Bar Chart
Solved1.63K views24th May 2024Dashboard and Query
Micah Brown [SLC] [DevOps Advocate]494 22nd May 2024 0 Comments
I made a bar chart using a query that gets each of the "Availability" parameters from all of the SLAs using "Skyline SLA Definition Basic" on this DMA. Even though each of the availabilities are from 0% to 100%, the bar chart shows it from 0.0% to 1.0%. Is there something I can add to either the bar chart settings or the query to fix this?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 24th May 2024
Sebastian Ulloa [SLC] [DevOps Advocate]2.34K Posted 22nd May 2024 1 Comment
Hi Micah,
Does the axis change if you select "Absolut" in the Char Layout settings of the component?
Micah Brown [SLC] [DevOps Advocate] commented 23rd May 2024
Hi Sebastian,
That fixed the issue for me. Thank you!
