Overflow in Interactive automation script
Solved589 views26th November 2025interactive automation script
Benjamin Hodžić [SLC] [DevOps Advocate]1.42K 6th November 2025 0 Comments
In Cube view of the IAS, for some reason the vertical overflow/scrollbar in my script is not appearing.
I've reduced the height to be less than what can be fitted with components, but the script still shows no overflow.
The red rectangles are actually sections, with 2 containing widgets. I've seen examples where only widgets will cause vertical overflow.
What can I do to make the scrollbar appear?
Thanks!
Benjamin Hodžić [SLC] [DevOps Advocate] Selected answer as best 26th November 2025
José Silva [SLC] [DevOps Enabler]1.91K Posted 6th November 2025 0 Comments
Hi Benjamin,
This is probably not the answer you were hoping for, but if the scrollbar isn’t available in the Cube native view, one possible workaround is to implement a kind of lazy-loading mechanism using “Next” and “Back” buttons.
This way, instead of relying on scrolling, you can display the content in smaller batches and still allow users to navigate through all items and interact with the buttons at the bottom.
It’s not ideal, but it ensures users can still access all necessary actions even when the UI layout prevents a scrollbar from appearing.
Kind regards,
José Silva [SLC] [DevOps Enabler] Edited answer 6th November 2025
