Order of multi-instance sections in DOM
Solved2.00K views17th October 2023DOM
Thomas Cauwelier [SLC] [DevOps Advocate]1.79K 17th October 2023 0 Comments
If my DomDefinition allows multiple instances of a section, can I rely on the order of the sections to be preserved when creating, reading, and updating the instance?
Should I include a "sequence number field" in my section if the order is important for my usecase?
Thomas Cauwelier [SLC] [DevOps Advocate] Selected answer as best 17th October 2023
Thomas Ghysbrecht [SLC] [DevOps Enabler]5.75K Posted 17th October 2023 0 Comments
Hi Thomas,
The DOM API should retain the exact order in which the Sections were added to the DOM instance. If the create/update interaction with this DOM data is solely done using the DOM helper, then there shouldn't be a need for this sequence number. However, if updates were done using a form in low-code apps, I currently cannot guarantee that the order will always remain the same. (I will double-check & update my comment)
Update: It looks like the web APIs do re-arrange the sections on the DOM instance according to the configuration. But looking at this logic, the sections belonging to the same SectionDefinition would remain in the same order. I would however recommend adding the sequence number in that case if the order is a critical part of the solution.
