NuGet Package References not installed
Solved2.47K views1st March 2023
Richard Henderson196 28th February 2023 0 Comments
In VizStudio I have cloned and opened a repo, it says the NuGet packages are installed but according to the QAction references they are not installed.
Any ideas what I’m missing?
Richard Henderson Selected answer as best 1st March 2023
Philip Argent [DevOps Advocate]1.13K Posted 1st March 2023 1 Comment
Following Joachim’s answer, also check you have the the nuget.org ‘https://api.nuget.org/v3/index.json’ package resource configured in the NuGet Package Manager.
Richard Henderson Edited comment 1st March 2023
Richard Henderson commented 1st March 2023
Thanks found it was a mix of both. But more of a setup issue of should of checked what you said first.
8
Joachim Ally [SLC] [DevOps Advocate]1.64K Posted 28th February 2023 2 Comments
Hi Richard,
When you clone a repo and open your solution in Visual Studio, you will indeed still have this problem. In your QActions, the SLProtocol will not be recognized for instance while the using Skyline.Dataminer.Scripting is there… 🤔
What you can do to fix this is going to your Solution Explorer and right-click on your solution called “Protocol”. In this menu, click on Restore Nuget Packages. 🖱️
In the Output Window (more specific to the output of the Package Manager) you will see some restore messages. 📃
And after that, you should see all these red curly braces magically disappear. 🪄
Joachim Ally [SLC] [DevOps Advocate] Edited comment 1st March 2023
that makes sense, worked as soon as I checked what Philip mentioned in his post. Dooh (always check your setup)
Joachim Ally [SLC] [DevOps Advocate] commented 1st March 2023
Okay, perfect! Happy coding! ‍
