NotifyType 220 vs NotifyType 336
Solved2.30K views25th November 2021Fillarray fillarray with collumn mediation protocol protocol.clear protocol.leave
Guilherme Gaspar [SLC] [DevOps Member]549 25th November 2021 0 Comments
NotifyType.NT_FILL_ARRAY_WITH_COLUMN (220)
vs
NotifyType.NT_FILL_ARRAY_WITH_COLUMN_ONLY_UPDATES (336)
What's the difference between them?
What's the history of 336? Is it related to the incorporation of Protocol.Clear and Protocol.Leave?
Guilherme Gaspar [SLC] [DevOps Member] Selected answer as best 25th November 2021
João Severino [SLC] [DevOps Enabler]14.78K Posted 25th November 2021 0 Comments
Hi Guilherme
According to the help, there is no difference.
See DataMiner Development Library
Not sure about the history but most likely it had some improvements that have since been merged also into Notify 220
