Multiple set within element – order of execution
Solved2.50K views13th June 2024multiple set
hans sanders [DevOps Advocate]618 12th June 2024 0 Comments
When using 'multiple parameter set' within an element, does one have control on the order of execution of the sets ?
As an example: for a cisco manager element we want to 'move' a vlan fron Trunk 'A' to trunck 'B' using the remove VLAn en Add Vlan parameters.
However we want to be sure that the 'remove VLAN' parameter is applied before the 'Add VLAN' parameter is set.
Pieter Van Compernolle [SLC] [DevOps Enabler] Selected answer as best 13th June 2024
Tom Van Bruaene [SLC] [DevOps Member]980 Posted 12th June 2024 1 Comment
The multiple sets are indeed send in the order you click them in Cube, and we do preserve that order throughout the flow.
Note that you can double-check the order in the confirmation box:
The order will match with what you see there.
The only exception is parameters that have dependencies, those will be grouped (see https://docs.dataminer.services/user-guide/Basic_Functionality/Parameters/Parameter_dependencies.html )
hans sanders [DevOps Advocate] commented 12th June 2024
Thanks a lot for the clear feedback.
I am re-assured !
