Multiple set within element – order of execution
Solved2.28K views13th June 2024multiple set
hans sanders [DevOps Advocate]618 12th June 2024 0 Comments
When using 'multiple parameter set' within an element, does one have control on the order of execution of the sets ?
As an example: for a cisco manager element we want to 'move' a vlan fron Trunk 'A' to trunck 'B' using the remove VLAn en Add Vlan parameters.
However we want to be sure that the 'remove VLAN' parameter is applied before the 'Add VLAN' parameter is set.
Pieter Van Compernolle [SLC] [DevOps Enabler] Selected answer as best 13th June 2024
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 12th June 2024 0 Comments
Hi Hans,
If the order of execution is important you could use an interactive automation script to do the sets. In that script you could then also check if the VLAN was properly removed before adding the new one or show an error message when that would not be the case.
Tom Waterbley [SLC] [DevOps Enabler] Edited answer 12th June 2024
