Multi select drop down in LCA
Solved1.31K views26th September 2024interactive automation script LCA multiselectdropdown
Hari priya Venkatesan [DevOps Advocate]1.06K 23rd September 2024 0 Comments
Hi Team,
I would to add a multi select drop down in my LCA either using LCA tools or Skyline.DataMiner.Utils.InteractiveAutomationScript library. I tried finding it in both. Is it possible to add a multiselect drop down in LCA
Hari priya Venkatesan [DevOps Advocate] Selected answer as best 26th September 2024
Daniela Prada [SLC] [DevOps Member]522 Posted 23rd September 2024 2 Comments
Indeed it is not possible to have mutiple selections in a drop down component.
Instead you can try using a Tree or a List component, which allows multiple selections.
Hari priya Venkatesan [DevOps Advocate] commented 25th September 2024
Thanks for the response, i would also like to know if Skyline.DataMiner.Utils.InteractiveAutomationScript has anything like the tree or list component as above.
Got a workaround. kindly ignore this
