Meinberg NMS – receiver elements
Solved3.11K views30th July 2024mbgNMS meinberg NMS
Rodrigo Vivar [DevOps Member]164 27th March 2024 0 Comments
We are developing some dashboard and when we tried to generate a dashboard with the Good Satellites and Satellites in view we detected that the receivers ELEMENTS doesn´t works properly in the MEINBERG modular devices
Looks like the Protocol of those modules (in our example GNM and GNS_UC) doesn’t works properly. Or we are doing something worng.
Before open this issue, we reapply the CIType, but the issue still. I had open a Ticket with Support, but perhaps someone in the community can help us.
The receivers looks fine in the Chasisis (see example, both clocks in green)
Inside the MAIN DEVICE CHASSIS The receivers has the correct S/N and the Firmware version
But when we go inside each receiver ELEMENT looks like are NOT initialized
The  general Tab is the only one that have some information
We had activated the Http comunication, and the element has comunication with the physical device
Thanks in advance
Rodrigo
Rodrigo Vivar [DevOps Member] Selected answer as best 30th July 2024
Stijn Declerck [SLC] [DevOps Advocate]824 Posted 28th May 2024 1 Comment
Hi Rodrigo,
These elements are indeed no DVE's. You don't see any data on the element pages because the connector fails when parsing the response. As discussed, these exceptions will be handled in the next version of the Meinberg LANTIME IMS-GNS_UC and Meinberg LANTIME IMS-GNM connectors.
Rodrigo Vivar [DevOps Member] Posted new comment 28th May 2024
Rodrigo Vivar [DevOps Member] commented 28th May 2024
Hi Stijn,
thank you very much. We will keep you infomed when we had installed the new release
